    Reasonable connection limits?
    1.9k
    • E
      elliotdickison
      Hi,
      I'm setting up FusionAuth in a multi-node cluster and am trying to determine a good connection limit for each node. If I give each node the recommended 512MB ram, how many connections could FusionAuth handle? Or is the number of connections CPU-bound? The majority of traffic will likely be to POST /api/jwt/refresh to refresh access tokens.
      Thanks!
        @elliotdickison
        We typically see the chokepoints for FusionAuth in either the CPU (when doing a lot of password hashing) or the database.
        More here: https://fusionauth.io/docs/v1/tech/installation-guide/monitor/#load-testing
        Since usage varies, I suggest you perform your own load testing to determine connection limits. Would love to see your conclusions!
