    To Get Applications and all it's associated roles
    4.0k
    • R
      ravikiran.sattigeri
      Hi FA Team,
      Please share best way to get list of all applications and it's associated roles.
      I have JSON with applications and it attributes. I need referecnece or script which you might be using for fetching only list of application and roles.
      Thanks in advance.
      • joshuaJ
        joshua @ravikiran.sattigeri
        Hi @ravikiran-sattigeri,
        All applications can be retrieved via this API -
        https://fusionauth.io/docs/v1/tech/apis/applications/#retrieve-an-application
        The roles should be attached to the returned object under a roles array.
        If you could provide some additional context around what you are attempting to accomplish, we may be able to provide additional feedback.
        If you have a support contract, please file a ticket via your Zendesk or Slack channels for additional questions. Thanks!
        Josh
