    How to define request headers in Kickstart?
    448
      jan.meznik
      I am writing a kickstart file, and I need to define the X-FusionAuth-TenantId header for the /api/application endpoint.
      However, I can find no documentation on how to do this in Kickstart, nor how I can get around this.
      Is this supported by Kickstart?
      • joshuaJ
        joshua @jan.meznik
        Hi @jan-meznik
        Please find our kickstart documentation below for reference:
        • https://fusionauth.io/docs/v1/tech/installation-guide/kickstart/
        With kickstart, you can programmatically create almost anything you can create with our APIs. We have some good example kickstart files that demonstrate how to build with this tool.
        https://github.com/FusionAuth/fusionauth-example-kickstart/blob/master/example-apps/joomla-sso.json
        In the above example, since we are using only one tenant, we can define this in the variables section.
        Additional information regarding using more than one tenant can be found in our documentation below.
        • https://fusionauth.io/docs/v1/tech/installation-guide/kickstart/#tenants
        Let us know sheds some light or if you have any other questions.
        Josh
        J 1 Reply Last reply Reply Quote 1
          jan.meznik @joshua
          Thanks for the reply @joshua.
          Although I still don't know if it is possible to set POST Header fields, the Kickstart file allows to do this by defining the tenantId in the root of the request. I'll paste it here directly, to make it easier for other visitors 🙂
                "method": "POST",
                "url": "/api/application",
                "tenantId": "#{secondTenantId}",
                "body": {
                  "application": {
                    "name": "My Cool Application"
          danD 1 Reply Last reply Reply Quote 2
          • J jan.meznik has marked this topic as solved on
            dan @jan.meznik
            @jan-meznik If there are other headers you need to set that are not supported, please file a github issue with the details: https://github.com/fusionauth/fusionauth-issues/issues
            FusionAuth - Auth for devs, built by devs.
