    tar: Error opening archive: Unrecognized archive format
    17.9k
    • P
      patrick
      When attempting to start a new FusionAuth installation (on MacOS 10.15.7 Catalina) I get the error...
      Manually running the startup script tar command...
      $ tar xfz "/Users/patrick/fusionauth/bin/../java/openjdk-macos-17.0.1+12.tar.gz" -C "/Users/patrick/fusionauth/bin/../jav
      ...produces the same error.
      So this is a problem with the downloaded file? Does anyone have a workaround for this? Maybe edit the startup script with a different java version?
      • joshuaJ
        joshua @patrick
        @patrick
        Please make sure that you are using the latest installation and version of FusionAuth which can be found below
        https://fusionauth.io/download/
        Josh
        P 1 Reply Last reply Reply Quote 0
        • P
          patrick @joshua
          @joshua
          Thanks for the reply. Yes, that command (for macOS)...
          sh -c "curl -fsSL https://raw.githubusercontent.com/FusionAuth/fusionauth-install/master/install.sh | sh"
          ...looks like the one I've been using from the 5-Minute Setup Guide.
          Just to be sure, I copied the command from that referenced download site and ran it. Unfortunately the same error was returned.
          • joshuaJ
            joshua @patrick
            @patrick
            I am wondering if you are running into the error described below:
            https://fusionauth.io/community/forum/topic/1415/startup-sh-fails-on-tar-of-openjdk-linux-gz
            Can you try the workaround suggested there and see if it resolves the issue?
            Josh
            • P
              patrick @joshua
              @joshua Yes, that solved my problem - FusionAuth started and responded at localhost:9011. Thank you!
              • joshuaJ
                joshua @patrick
                @patrick
                Perfect 👌
