    Issue with my web hooks (works in settings->webhooks->test) but not in API
    • D
      dmadhusudan
      Hi ,
      I have created test web hook for my application(user.create) and mapped with application/tenant.
      I have tested the webhook with (settings->webhooks->test webhook option) there it is able to send event , and I am able to see the event at my web app too.
      But same If I try to create user with API for the same tenant/application , there is no event is getting generated, and not able to see the logs too
      Please help
        dan @dmadhusudan
        @dmadhusudan
        What version of FusionAuth are you running?
        Have you enabled the webhook in both Settings -> Webhooks and under the Tenant -> Webhooks section?
