    Java verification code for HS256 signed id token
    2.5k
    • G
      gokul.mahajan20
      How to verify HS256 ID Token using FusionAuth java Client libraries ?
      Description: I have created an app in FusionAuth that has a Clinet ID and Client Secret generated, I have not touched any other section/tab like JWT etc, default JWT signing algo is OIDC standard HMAC SHA256.
      I tried using following code approach to validate the token based on public key, but its not working for HS256 signed token, I searched over internet and found public key is not applicable for HS256
      Could you please provide me a Java code to verify HS256 signed token using FusionAuth Java client libraries (https://github.com/FusionAuth/fusionauth-jwt).
      Please also let me know that do I need any additional configuration on FusionAuth Admin Console.
      Code which I tried: Its giving blank public keys.
          List<JSONWebKey> keys = JSONWebKeySetHelper.retrieveKeysFromJWKS("http://localhost:9011/.well-known/jwks.json");
          Map<String, Verifier> publicKeyVerifiers = new HashMap<String, Verifier>();
          JWT jwtDecoded = JWT.getDecoder().decode(idToken, publicKeyVerifiers);
        dan @gokul.mahajan20
        @gokul-mahajan20 I think you can find examples here: https://github.com/FusionAuth/fusionauth-jwt/#sign-and-encode-a-jwt-using-hmac
