Is there an option to use a captch solution with FusionAuth / plugin looks to only support password encryption. Are there any examples to view?
Hiya,
I'm sorry, I'm not sure I quite understand. Can you explain more about what you'd like to do? Do you want to add a captcha to the login form?
If that's what you're looking to do, we have an outstanding feature request: https://github.com/FusionAuth/fusionauth-issues/issues/278 Please give it a thumbs up to vote for it.
We unfortunately don't have any timeline for implementing this at present.
If I misunderstood your question, please give more details about what you are trying to accomplish.
Hi Dan,
Thx for the response - correct, re the login form, and adding a captcha solution. -
