    FusionAuth Cookies
    4.6k
    • Q
      quent
      FusionAuth seems to always create those 2 cookies when hitting the log page, even before logging:
      • fusionauth.sso
      • fusionauth.locale
      Is it normal behaviour?
      • joshuaJ
        joshua @quent
        @quent
        FusionAuth uses cookies as part of a login flow - so this is likely expected.
        Josh
        Q 1 Reply Last reply Reply Quote 0
        • Q
          quent @joshua
          @joshua
          but, even before logging ? I was expected to be created after successful loging, and being deleted after a logout (note it is not a matter to me, just trying to understand if what i see in my implementation is normal)
          • joshuaJ
            joshua @quent
            @quent
            This does not seem unexpected to me. FusionAuth uses cookies at various times depending on the workflow/process, so what you are seeing is likely normal.
            Josh
            • Q
              quent @joshua
              @joshua Thank you 🙂
                dan @quent
                @quent We have a list of typical cookies set by the hosted login pages here: https://fusionauth.io/docs/v1/tech/reference/cookies
                • Q quent has marked this topic as solved on
