    Fusionauth Installation Issue
    • H
      hanumant.sidraya
      Fusion Auth is not working
      Command
      . { iwr -useb https://raw.githubusercontent.com/FusionAuth/fusionauth-install/master/install.ps1 } | iex; install
      After Installation and running the following command
      .\fusionauth\bin\startup.bat
      This is Output Window is coming
      NOTE: Picked up JDK_JAVA_OPTIONS: --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-opens=java.base/java.util.concurrent=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
      2022-03-22 5:40:42.310 PM WARNING org.apache.tomcat.util.digester.Digester - [SetPropertiesRule]{Server} Setting property 'port' to '${fusionauth-app.management.port}' did not find a matching property.
      2022-03-22 5:40:42.368 PM WARNING org.apache.tomcat.util.digester.Digester - [SetAllPropertiesRule]{Server/Service/Connector} Setting property 'port' to '${fusionauth-app.http.port}' did not find a matching property.
      2022-03-22 5:40:42.369 PM WARNING org.apache.tomcat.util.digester.Digester - [SetAllPropertiesRule]{Server/Service/Connector} Setting property 'redirectPort' to '${fusionauth-app.https.port}' did not find a matching property.
      2022-03-22 5:40:42.374 PM WARNING org.apache.tomcat.util.digester.Digester - [SetAllPropertiesRule]{Server/Service/Connector} Setting property 'port' to '${fusionauth-app.https.port}' did not find a matching property.
      2022-03-22 5:40:42.390 PM WARNING org.apache.tomcat.util.digester.Digester - [SetAllPropertiesRule]{Server/Service/Connector} Setting property 'port' to '${fusionauth-app.ajp.port}' did not find a matching property.
      2022-03-22 5:40:42.463 PM INFO org.apache.catalina.core.AprLifecycleListener - The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [D:\userauth3\fusionauth\java\jdk-17.0.1+12\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Program Files\Common Files\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Windows\System32\OpenSSH;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\110\Tools\Binn;C:\Program Files\dotnet;C:\Program Files\Microsoft SQL Server\130\Tools\Binn;C:\Program Files\Microsoft\Azure Functions Core Tools;C:\Program Files\nodejs;C:\Program Files\Git\cmd;C:\Users\hanumant.sidraya\AppData\Roaming\npm;C:\Program Files\Microsoft\Web Platform Installer;C:\Program Files (x86)\dotnet;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn;D:\JMeter\bin;%JAVA_HOME%\bin;C:\Program Files (x86)\Microsoft SQL Server\150\DTS\Binn;C:\Program Files\Azure Data Studio\bin;C:\Program Files\Java\jdk-16\bin;C:\Users\hanumant.sidraya\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\hanumant.sidraya.dotnet\tools;C:\Users\hanumant.sidraya\AppData\Roaming\npm;C:\Program Files\mongosh;.]
      2022-03-22 5:40:42.671 PM INFO org.apache.coyote.http11.Http11NioProtocol - Initializing ProtocolHandler ["http-nio-auto-1"]
      2022-03-22 5:40:42.751 PM INFO org.apache.tomcat.util.net.NioSelectorPool - Using a shared selector for servlet write/read
      2022-03-22 5:40:42.759 PM INFO org.apache.coyote.http11.Http11NioProtocol - Initializing ProtocolHandler ["https-jsse-nio-auto-2"]
      2022-03-22 5:40:42.887 PM INFO org.apache.tomcat.util.net.NioSelectorPool - Using a shared selector for servlet write/read
      2022-03-22 5:40:42.889 PM INFO org.apache.coyote.ajp.AjpNioProtocol - Initializing ProtocolHandler ["ajp-nio-127.0.0.1-auto-3"]
      2022-03-22 5:40:42.905 PM INFO org.apache.tomcat.util.net.NioSelectorPool - Using a shared selector for servlet write/read
      2022-03-22 5:40:42.907 PM INFO org.apache.catalina.startup.Catalina - Initialization processed in 659 ms
      2022-03-22 5:40:42.915 PM INFO org.apache.catalina.core.StandardService - Starting service [Catalina]
      2022-03-22 5:40:42.916 PM INFO org.apache.catalina.core.StandardEngine - Starting Servlet engine: [Apache Tomcat/8.5.72]
      2022-03-22 5:40:44.648 PM INFO org.apache.jasper.servlet.TldScanner - At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
      2022-03-22 5:40:45.783 PM SEVERE org.apache.catalina.core.StandardService - Failed to start connector [Connector[HTTP/1.1-auto-1]]
      2022-03-22 5:40:45.784 PM SEVERE org.apache.catalina.core.StandardService - Failed to start connector [Connector[HTTP/1.1-auto-2]]
      2022-03-22 5:40:45.785 PM SEVERE org.apache.catalina.core.StandardService - Failed to start connector [Connector[AJP/1.3-auto-3]]
      2022-03-22 5:40:45.788 PM INFO org.apache.catalina.startup.Catalina - Server startup in 2879 ms
      After that, I'm not able to access the URL: http://localhost:9011/
      • H
        hanumant.sidraya
        fusion Auth Version 1.35.0
        • B
          beroetz
          I have absolutely the same problem.
          Installation on Windows 10.
