    What are the pros and cons of using the default tenant?
    1.7k
    • G
      gg-dev
      The default tenant includes the FusionAuth application – is it better to create a separate tenant for your application(s), or to use the default tenant?
      What are the pros and cons?
        dan @gg-dev
        @gg-dev This is a great question. It depends on what you want to do and how complex your integration is.
        For load and migration testing, we recommend using a separate tenant as that makes it easy to remove many users repeatedly (you just drop the tenant).
        The only Application which must live in the default tenant is the FusionAuth application (the admin UI which can be used to configure and manage FusionAuth itself).
        If you are planning to do all management via API or other config management tools, you might not care much about the FusionAuth application and so might be fine with everyone in the same tenant. More about config management: https://fusionauth.io/docs/v1/tech/admin-guide/configuration-management
        If you think you want different tenant settings (password complexity, themes, password hashing, MFA options) for the majority of your users and your FusionAuth admin users, then using two or more tenants can make sense.
        If you are private labelling your app and have multiple user spaces, then you'll want multiple tenants. More here: https://fusionauth.io/blog/2020/06/30/private-labeling-with-multi-tenant
        Using a separate tenant allows for more separation:
        • no way to accidentally register a normal user for the FusionAuth admin application
        • can lock API keys down to a separate tenant so that they could never be used to modify FusionAuth or add users
        • users can have different sets of credentials for the user tenant and the default tenant
        Downsides of using multiple tenants:
        • can't share one password or SSO between other applications and the admin UI (for admin users)
        • have to apply the tenant id header for most API calls
        G 1 Reply Last reply Reply Quote 0
        • G
          gg-dev @dan
          Thanks Dan. I think we'll go with separate tenants.
          (Apologies for the late reply, I wasn't auto-subscribed to this topic.)
