    Using custom login page while implementing SSO
    3.1k
    • V
      vindhyahegde2114
      Is there anyway we can use our own, existing login pages of applications to implement SSO?
        dan @vindhyahegde2114
        @vindhyahegde2114
        At this time, SSO is only supported if you use the hosted login pages:
        Additionally, when you use the hosted login pages, FusionAuth provides transparent single sign on (SSO) between applications as well as support for localization of the user interface.
        https://fusionauth.io/docs/v1/tech/core-concepts/integration-points#hosted-login-pages
        There's an open issue to expose SSO management via an API: https://github.com/FusionAuth/fusionauth-issues/issues/1515
        Please vote it up and/or add a comment about your use case if you'd like.
        As a reminder, here's our roadmap guidance: https://fusionauth.io/docs/v1/tech/core-concepts/roadmap
