    Custom parameters in callback method
    1.8k
    • F
      francis.ducharme
      Hi there!
      Is there any way in the login process to have custom parameters received in the defined callback method ?
      As you can see, I am redirecting the user's browser to a static URL, but I'd like this URL to be dynamic, depending on custom parameters received when Google (the identity provider in this case) calls my Callback method
      Is this possible ?
      • joshuaJ
        joshua @francis.ducharme
        @francis-ducharme
        To confirm, you are:
        1. Sending the user to a page such as:
        https://local.fusionauth.io/oauth2/authorize?client_id=85a03867-dccf-4882-adde-1a79aeec50df&response_type=code&redirect_uri=https%3A%2F%2Fthird.com
        1. The user will click login with Google or be redirected automatically to Google (if using an idp_hint, for instance)
        In this case, FusionAuth will redirect to https://third.com (example only) but could just as easily redirect to https://fourth.com depending on step one. In either case, all possible redirect URLs for your application need to be previously defined on the OAuth configuration for that application.
        Also, we do have a few github issues allowing a wildcard to be defined for a redirect URL.
        • https://github.com/FusionAuth/fusionauth-issues/issues/437
        With more context, I might be able to provide additional feedback. Depending on context, deeplinking might also be something worth exploring
        • https://www.youtube.com/watch?v=-vx5rdy-mvY
        Josh
