    Problem between oauth2/authorize code and oauth2/token in android
    4.8k
    • C
      cgonzalez
      I have a weird problem in ionic app, in iOS is working without problem but in android the code is wrong.
      The only difference I notice is the locale in the two responses:
      iOS:
      https://[url]?code=[code]&locale=es_419&userState=Authenticated
      This code is working.
      Android
      https://[url]?code=[code]&locale=en_US&userState=Authenticated
      This code is not working
      I pass this code to oauth2/token in the same way, but in Android es responding:
      {"error":"invalid_request","error_description":"Invalid Authorization Code","error_reason":"auth_code_not_found"}
      I try to add locale in oauth2/authorize but the response is the same.
      • joshuaJ
        joshua @cgonzalez
        Hi @cgonzalez
        Can you confirm how quickly you are completing the exchange for a token using the code?
        The code may not be available if:
        1. It has expired or
        2. It as already been used to obtain a token.
        Josh
