Having an issue with nginx in front of FusionAuth
I use FusionAuth with nginx as a reverse proxy in front of it. After upgrading to version 1.41, I see this error message:
2022/11/28 01:59:25 [error] 28#28: *1 upstream prematurely closed connection while reading response header from upstream, client: 192.168.0.1, server: , request: "GET / HTTP/1.1", upstream: "http://192.168.0.2:9011/", host: "localhost"This was working before I upgraded. I was using version 1.36 before.
Ah, the answer is that Nginx defaults to HTTP/1.0 and if you are on a recent version of FusionAuth, this protocol is not supported by our HTTP server (HTTP 1.1 was, after all, released in 1997
).The remedy is to update your Nginx configuration to use a later protocol with this change:
proxy_http_version 1.1;Hope that helps.
Hi Guys,
Your reply helped me as well. Thank you. I'm still struggling with the issue of rewriting /admin when using subpath.
When I click login icon I'm redirected with 302 to $host/admin not $host/fa/admin
This happened after I updated my FA.location /fa/ { proxy_http_version 1.1; proxy_set_header X-Forwarded-Proto https; proxy_set_header X-Forwarded-Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header X-Forwarded-Server $host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Accept-Encoding ""; sub_filter 'action="/' 'action="/fa/'; sub_filter 'href="/' 'href="/fa/'; sub_filter 'href="/admin/' 'href="/fa/admin/'; sub_filter 'src="/images' 'src="/fa/images'; sub_filter 'src="/js' 'src="/fa/js'; sub_filter_once off; proxy_pass http://localhost:9011/; } location ~^/(?<fusionPath>(oauth2|admin|ajax|login|password|js/identityProvider))/ { proxy_pass http://127.0.0.1:9011/$fusionPath/; # https://fusionauth.io/docs/v1/tech/admin-guide/proxy-setup#how-to-use-a-proxy proxy_set_header X-Forwarded-Proto https; proxy_set_header X-Forwarded-Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header X-Forwarded-Server $host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Accept-Encoding ""; sub_filter 'action="/' 'action="/fa/'; sub_filter 'href="/' 'href="/fa/'; sub_filter 'src="/images' 'src="/fa/images'; sub_filter 'src="/admin' 'src="/fa/admin'; sub_filter 'src="/js' 'src="/fa/js'; sub_filter_once off; } -
D dan referenced this topic on
