    Issue with use OAuth with react blog - using NextJs ts
    2.2k
    • R
      rationem
      Hi,
      I am attempting to follow the OAuth with react blog
      My stack uses NextJs and NestJs (built on express).
      In the server login route, I am getting a typescript error.
      The code with the error is:
      @Get('/login')
        public async login(@Req()request: Request, @Res() response: Response){
          const state = crypto.randomBytes(64)
          request.session.oauthState = state;
      The typescript error is
      Property 'oauthState' does not exist on type 'Session & Partial<SessionData>'.ts(2339)
      I have the latest types definition file
      @types/express-session": "^1.17.5",
      Could you assist?
      Many thanks
      K 1 Reply Last reply Reply Quote 0
      • K
        kasir-barati @rationem
        @rationem You could look at my backend app in this monorepo: https://github.com/kasir-barati/you-say
        There I've implemented a NestJS custom backend app. BTW I have a question for you, right now my NextJS frontend build is broken and I do not know why, I mean I kinda know that it is because I am using @fusionauth/react-sdk and it needs to have access to document object but since during build it does not have that my build is defective. Any suggestion?
        I also read this doc but it was not what I wanted since it was communicating directly with FusionAuth and in my case I do not want that 🙂.
