    Hosting using a shared hosting plan with a company like ionos
    1.1k
    • G
      gcasson-ceo
      Is it possible for me to host fusion auth using my shared plan with ionos if so how?
        dan @gcasson-ceo
        @gcasson-ceo
        I'm not familiar with Ionos, but if you can run a database and the OS is linux, windows or mac, you should be able to run FusionAuth.
        Reading the system requirements will help you determine if the Ionos shared plan offers enough RAM and other resources: https://fusionauth.io/docs/v1/tech/installation-guide/system-requirements
