    Issue with istio and FusionAuth
    istio kubernetes
    3.6k
      We're trying to use FusionAuth with istio and oauth2-proxy to protect resources in kubernetes. We have another idp that we are using, and the system works fine.
      But when we try to use FusionAuth, we see these messages:
      No valid authentication in request. Initiating login.
      Error redeeming code during OAuth2 callback: could not verify id_token: failed to verify token: failed to verify signature: failed to verify id token signature
      Not quite sure where to go from here.
        dan @dan
        There are a couple of things to check:
        • make sure that you've updated the issuer at the tenant screen: https://fusionauth.io/docs/v1/tech/core-concepts/tenants#general
        • make sure you are using an asymmetric keypair to sign the id token. If you are using HMAC, which is the default for FusionAuth, you have to share a secret. Asymmetric algorithms like RSA256 are what proxies typically need (so they don't have to have the signing secret). More here: https://fusionauth.io/docs/v1/tech/core-concepts/applications#jwt and here: https://fusionauth.io/docs/v1/tech/core-concepts/key-master
        Hope that helps.
        • danD dan has marked this topic as solved on
