    Problem running Flask server - Dashboard page not found (404 error)
    4.1k
    • E
      eric.vigiani
      I'm facing an issue while setting up FusionAuth with Flask. I followed the configuration steps to integrate FusionAuth into my Flask application, but I'm having difficulty accessing the dashboard page after starting the Flask server.
      Here is the configuration I'm using:
      I have a Flask application with the following routes:
      Main route (/) that redirects to the FusionAuth login page.
      Logout route (/logout) that clears the user session and redirects to the main page.
      Dashboard route (/dashboard) that should display the dashboard page with additional user information.
      I created the corresponding HTML pages (home.html, dashboard.html) and placed them in the 'templates' folder of my Flask project.
      I ensured that the routes are correctly defined in the code and that the URLs are properly specified in the HTML pages.
      I verified that all the necessary dependencies are correctly installed.
      After starting the Flask server, I can access the home page and successfully login using FusionAuth. However, when I try to access the dashboard page (/dashboard), I receive a 404 error indicating that the page was not found.
      in the flask documentation https://fusionauth.io/docs/v1/tech/tutorials/integrate-python-flask, i am trying to undestand this section.
        @eric-vigiani Sorry about that! We pull in the code for server.py from GitHub, and it looks like it is missing.
        We have a new, simpler python flask tutorial: https://fusionauth.io/docs/quickstarts/quickstart-python-flask-web
        which we just reviewed and tested.
        Sorry for the hassle!
