    Different Roles for Different Products
    1.6k
    • M
      matthieu
      Hello !
      I have one application for which I created a list of roles.
      In this application, a user can access several different products, but I would like my user to have some roles when he is accessing product 1, and other roles when accessing product 2.
      For now I use entity grants where the permissions are the list of my products to determine in my backend code if the user is allowed to access a product.
      But the problem is that if a user has permissions for 2 products, he will have the same list of roles for both products.
      The best would be to assign to a user, a pair role/product.
      Is there a way to do this ?
      Thank you
      mark.robustelliM 1 Reply Last reply Reply Quote 1
        mark.robustelli @matthieu
        @matthieu ,
        Why would the roles not work with the product as a prefix and the right as the suffix not work as a role?
        I.E.
        • product1_read
        • product1_write
        • product1_delete
        • prodcut2_read
        • product2_write
        • product2_delete
        • M
          matthieu @mark.robustelli
          @mark-robustelli
          It would work, but I was looking for a method to avoid duplicating all the roles as they will be the same for all products.
          It would also mean I don't have to parse the role to separate the real role from the concerned product.
            @matthieu , that is understandable. Keep in mind if you are adding a lot of products often, you can use the APIs to help create and manage those permissions.
            I.E. Create an Application Role, Create an Entity, Update a User Registration (for updating roles)
