    Reverse Proxy - Problem with FusionAuth Server address
    2.3k
      mark.robustelli
      Is it possible to setup a FusionAuth server behind a reverse proxy and configure another redirect URI as to not expose the local address of the FusionAuth server directly? I am using FusionAuth behind a reverse proxy with an IdentityProvider login. The redirect after the login points the user to the private machine name of the FusionAuth server that is not reachable.
        mark.robustelli @mark.robustelli
        Make sure you these 4 headers in your proxy
        • Forwarded-Proto: typically this will be https. This ensures any redirects are sent with the appropriate scheme.
        • Forwarded-Host: The original host requested by the client in the Host HTTP request header.
        • Forwarded-For: The originating IP address of the client.
        • Forwarded-Server: The hostname of the proxy server.
        • mark.robustelliM mark.robustelli has marked this topic as solved on
