    Max Add Users to Group
    1.3k
      A Former User
      In the Add Users to Group API request it takes in an array of users. What is the max number of users that can be added in a single request?
      https://fusionauth.io/docs/v1/tech/apis/groups#add-users-to-a-group
        A Former User
        There are no hard limits as to the number of users you can add.
        If you notice any load spikes, you can always batch the work into multiple API calls.
        • System has marked this topic as solved on
