    FusionAuth Doesn't Start
    1.4k
    • A
      andrew 1
      When I run: .\startup.ps1
      I see:
      Starting fusionauth-app...
      --> Logging to C:\Users\Andrew Knox\fusionauth\logs\fusionauth-app.log
      I'm on Windows 10, have installed node (v18) and PostgreSQL (v10). I've not included Elastic.
      I can't seem to find another issue like this and the install appeared to work okay, "Install is complete. Time for tacos."
      Any ideas anyone?
      Andrew
      • A
        andrew 1
        I got this to work in the end and set up my application + users in the web UI.
        I deleted the installation and tried again from scratch into a different folder. I originally used a folder with spaces - that initially caused an issue and I had to amend one of the PS scripts to wrap a folder path in quotes so must have been linked to that as I didn't do anything different the second time around.
          dan @andrew 1
          @andrew-1 Thanks for sharing the fix! Appreciate it!
          • A andrew 1 has marked this topic as solved on
