    Change password flow across devices
    1.3k
      I have a situation that is a bit confusing. I'm using the hosted login pages, and have both mobile and web apps.
      I have users who start a change password flow on the mobile app, but then want to complete it on the webapp. The issue I'm running into is that the mobile app has a redirect that looks like fusionauth.demo:/oauthredirect but that doesn't work with the webapp, which looks like https://example.com/oauth-redirect.
      So the password ends up being changed, but the user is not sent to the correct redirect URL and so is not logged in to our app correctly.
      Any suggestions?
        dan @dan
        You have a few options, none of them great.
        • You could look at using universal links and android app links to make sure the redirect URL for both mobile and web apps has the same format.
        • You could, on the Change Password Template, put in a message making it clear to users that if they started the change password flow on a mobile device, they should finish it on a mobile device (and same with web apps).
        • You could, on the Change Password Template, write javascript to examine the user-agent and the redirect URL. If they are incompatible, you could redirect the user to a device-compatible change password URL (basically by rebuilding the change password link they clicked on to start the flow and then doing a window.location=... call).
