    Login records not showing application for token authentication
    1.3k
    • D
      devsoep
      Hi,
      We've noticed that users authenticated via the /oauth2/token endpoint are shown in the login records, but the application / application id are not set. Seems strange as the client credentials are provided, so the application should be known.
      Is this by design or something in our configuration? Any thoughts?
      Cheers,
      Peter
      • D
        devsoep
        Okay, so it seems to be by design. But why consider this successful? https://github.com/FusionAuth/fusionauth-issues/issues/1387
        • D
          devsoep
          Okay, so the docs also describe the requirement for testing the applicationId claim:
          https://fusionauth.io/docs/v1/tech/core-concepts/authentication-authorization#:~:text=Authorization and Securing Your Application
          Unfortunately the application feature Registration->Self-service registration doesn't work for token requests. And OAuth->Require registration doesn't work for password grant type.
