    Does FusionAuth support reporting internal system metrics for better observability?
    1.6k
      A Former User
      Does FusionAuth support any kind of OpenTelemetry or similar for reporting internal system metrics for better observability?
        A Former User
        You can add the opentelemtry java agent as described here: https://fusionauth.io/docs/v1/tech/admin-guide/monitor#opentelemetry
        We also have an open issue to better support open telemetry with spans. https://github.com/FusionAuth/fusionauth-issues/issues/1665
        If you are looking for alerts you can checkout how to setup Prometheus
        https://fusionauth.io/docs/v1/tech/tutorials/prometheus
        • System has marked this topic as solved on
