    Setting a certificate for FusionAuth
    1.9k
      What is the environment variable to set fusionauth-app.https.certificate? I want to use FusionAuth with HTTPS without using a proxy.
      It doesn't seem to match the documented syntax?
      https://fusionauth.io/docs/v1/tech/reference/configuration
        dan @dan
        FUSIONAUTH_APP_HTTPS_CERTIFICATE would be the variable name to use.
        However, properly escaping a multi-line certificate can be tricky.
        If you can write the cert out to a file, you could set FUSIONAUTH_HTTPS_CERTIFICATE_FILE instead, which doesn't have the escaping complexity.
        • danD dan has marked this topic as solved on
