    docker compose issue
    4.7k
      I encounter an issue when I run "docker-compose up -d" is the following:
      "ERROR: The Compose file './docker-compose.yml' is invalid because:
      services.search.environment.plugins.security.disabled contains true, which is an invalid type, it should be a string, number, or a null"
      If I change the values from true to "true" or from true to "1", the opensearch container restarts regularly and has the status "unhealthy".
      What can I do here?
        dan @dan
        Hmmm
        If this is the docker compose file you are using ( https://github.com/FusionAuth/fusionauth-containers/blob/master/docker/fusionauth/docker-compose.yml )
        Then https://opensearch.org/docs/2.11/security/configuration/disable/ indicates that is the correct value.
        Which docker compose file are you using?
        • R
          ryan.hopper
          This wasn't me who reported, but I got this error on he most up to date compose file.
          After a quick look, the machine I was trying to run it on was running an old version of docker, and was using docker compose v1 instead of 2.
          Updating the compose version to v2 addressed this issue.
            dan @ryan.hopper
            @ryan-hopper Thanks for sharing that info. Appreciate it!
