    Maximum lifetime of refresh token not honored? (sliding window configuration)
    1.7k
    • E
      egg
      Hi,
      I am configuring my Tenant with a refresh token expiration policy of "sliding window with maximum lifetime". I have configured the maximum lifetime to 240 minutes, but the refresh token is actually expiring after 30 minutes.
      What could be happening?
      Ernesto
        jenkinsbarlow9214250
        @egg said in Maximum lifetime of refresh token not honored? (sliding window configuration):
        The "sliding window with maximum lifetime" policy should allow the refresh token to remain valid as long as it's used within the configured lifetime, which in your case is set to 240 minutes.
