    The Best Ways to Use FusionAuth for Multi-Factor Authentication (MFA)
    23.6k
    • D
      dom9
      Hello Everyone 😊,
      I'm currently utilising FusionAuth to create Multi-Factor Authentication (MFA) in an effort to strengthen the security of our application. Even though the material has been quite beneficial, I wanted to ask the community of some more tips and best practices.
      I have the following specific queries:
      Designing User Experience (UX): In order to guarantee a seamless and simple user experience, how have you incorporated MFA into your application's login process? šŸ¤” Which UI/UX guidelines or design patterns have you discovered to be very successful? šŸ¤”
      Authenticator apps versus SMS: What aspects of employing SMS-based codes versus the authentication tool apps (such as Authy or Google Authenticator) did you take into account? šŸ¤” Did user preferences or security considerations influence your choice in either direction? šŸ¤”
      Fallback Procedures: What backup plans do you have in place in case a user misplaces or deletes the authenticator app, losing access to their primary MFA method? šŸ¤” In these situations, how can security and usability be balanced? šŸ¤”
      Scaling and Performance: Have there been any performance problems for those of you who have used MFA in large-scale applications? šŸ¤” If yes, how did you respond to them? šŸ¤”
      Regulations and Conformance: Does your MFA deployment approach take into account any particular compliance requirements or legislation (such GDPR, HIPAA, etc.)? šŸ¤” How did you make sure your implementation complies with these specifications? šŸ¤”
      https://fusionauth.io/articles/authentication/multi-factor-power-apps-authentication
      I would be interested in knowing about your implementation process experiences and any difficulties you encountered. I would be grateful for any advice, code snippets, or tools you could provide.
      Thank you šŸ‘ in advance.
      • R
        reply 1
        "I’m grateful for your support. Thanks a lot!"
