    Connection Issues Between FusionAuth and PostgreSQL in Kubernetes on Docker Desktop
    4.4k
    • V
      vinaymanepalli30
      I am running Kubernetes, which is enabled in the Docker Desktop application on my system. My application (Fusion AUTH) is running in pods, and I need to connect to a PostgreSQL database on my localhost. Both are installed on the same system, but I cannot establish a connection. I have also tried using the Docker bridge network.
      For the database connection string, I attempted the following:
      * Server=host.docker.internal;Database=yourdatabase;User Id=yourusername;Password=yourpassword;
      * jdbc:postgresql://host.docker.internal:5432/yourdatabase?user=yourusername&password=yourpassword
      * 127.0.0.1 kubernetes.docker.internal
      * localhost
      *  host.docker.internal
      Blow my yaml file
      # Here my pod deployment file
      apiVersion: apps/v1
      kind: Deployment
      metadata:
        name: fusionauth # Deployment for FusionAuth application
        namespace: fusionauth
      spec:
        replicas: 1 # Number of FusionAuth replicas
        selector:
          matchLabels:
            app: fusionauth # Label to identify the FusionAuth deployment
        template:
          metadata:
            labels:
              app: fusionauth # Labels for the pods
          spec:
            containers:
            - name: fusionauth
              image: fusionauth/fusionauth-app:latest # Latest FusionAuth image
              env:
              - name: DATABASE_URL
                value: jdbc:postgresql://host.docker.internal:5432/postgressql # Database connection string
              - name: DATABASE_USERNAME
                value: postgresadmin # PostgreSQL username
              - name: DATABASE_PASSWORD
                value: PGSqlAdm1n@$2024 # PostgreSQL password
              - name: DATABASE_DRIVER_CLASS_NAME
                value: org.postgresql.Driver # PostgreSQL driver class name
              ports:
              - containerPort: 9011 # Exposing FusionAuth port
              resources:
                requests:
                  memory: "512Mi" # Minimum memory request
                  cpu: "500m" # Minimum CPU request
                limits:
                  memory: "1Gi" # Maximum memory limit
                  cpu: "1" # Maximum CPU limit
      # Here k8s service
      apiVersion: v1
      kind: Service
      metadata:
       name: fusionauth # Service for FusionAuth
      spec:
       ports:
       - port: 9011 # Port to access FusionAuth
         targetPort: 9011 # Target port on the FusionAuth pod
       selector:
         app: fusionauth
      # here k8s ingress
      apiVersion: networking.k8s.io/v1
      kind: Ingress
      metadata:
      spec:
      ingressClassName: nginx
      rules:
      - http:
          paths:
          - path: /
            pathType: Prefix
            backend:
              service:
                port:
                  number: 9011
      Blow my yaml file
      apiVersion: apps/v1
      kind: Deployment
      metadata:
      spec:
        selector:
          matchLabels:
        template:
          metadata:
            labels:
          spec:
            containers:
            - name: fusionauth
              env:
              ports:
              resources:
                requests:
                limits:
      # Here k8s service
      apiVersion: v1
      kind: Service
      metadata:
      spec:
       ports:
       selector:
         app: fusionauth
      # here k8s ingress
      kind: Ingress
      metadata:
      spec:
      rules:
      - http:
          paths:
          - path: /
            pathType: Prefix
            backend:
              service:
                port:
                  number: 9011
        mark.robustelli @vinaymanepalli30
        @vinaymanepalli30 I am not a Kubernetes expert by any means. It looks like you have the right approach. Can you connect the localhost db from the localhost? Can you run and share your ip config once all the machines are up and running?
