I am looking into using FusionAuth. We have a business need for TikTok login, it seems they don't follow the OpenID standard requiring a client_key in place of the usual client_id so using the Add OpenID Connect option does not work.
Does someone more knowledgable know if it's possible for me to create a custom identity provider, modify the OpenID Connect one or support it in some other way? Any help would be greatly appreciated
@adam-rahman It looks like TikTok is not adhering to the OAuth2 standards. I'm not sure why. I have put an email into them to see if there is any reason and I will let you know if I hear anything back. I have looked around a bit, and cannot seem to find a why to change the parameter in the querystring through FusionAuth. There is currently an open Github issue for this. I added a comment but I suggest you go and upvote it too. You may also want to reach out to TikTok and ask them to get compliant.
@mark-robustelli thanks Mark. I've upvoted and added a comment also, i'll reach out to TikTok too but most likely it'll fall on death ears
M mark.robustelli has marked this topic as solved on
@adam-rahman Thanks. I'll keep an eye on this as well and reach out if I see any movement or hear anything.
@adam-rahman I heard back from TikTok. Not a very detailed response, but pretty clear they are not going to change anything.
Thank you for reaching out to TikTok for Developers Support.I'm sorry that this can't be changed at present.
"For now, I will continue to push the issue internally. If there is progress, we will update the Github issue.
