Setting SMTP settings
Hi
I have problem with setting SMPT settings locally. I tried to set up these settings so that I can use email verification but when i enter all details and try to send test email it return me messageUnable to send email via JavaMailCould not connect to SMTP host: smtp.eu.mailgun.org, port: 25and same settings use my colleague and it works when he test it.
I put host, port 25, username, password, security none, from address, from name but still getting this message that is unable to send and i don't see any problem if I have same settings as colleague. -
Hmm. That's weird.
I don't see anything wrong with your config, especially if your colleague uses it. I'd suggest:
- trying a different smtp host/solution (sendgrid has a free option)
- opening up a ticket with mailgun
I tend to use a local solution like mailcatcher, since email deliverability is a bit of a dark art.
