    How use mobile number for authentication
    7
    15.3k
    • M
      mehr.prs
      Hi,
      I want to use mobile number + password as my authentication fields and also
      verify users using SMS verification code in the register process.
      But I don't know how should I do that 🙂
        Hiya,
        If you want to do this, you'll probably want to have the mobile number be the username (also known as the loginId). You can change the messages file in the theme so that anywhere the username field is shown, the corresponding label is "mobile phone number".
        As far as using SMS verification, that will be something you have to build using the FusionAuth APIs. You would create a user using one of the user apis. Make sure you enable registration verification and then also pass the skipRegistrationVerification parameter to the API call.
        Then, you would send the SMS message using whatever method you want. Include a URL for your application and when the user enters the code correctly, you can call this method: https://fusionauth.io/docs/v1/tech/apis/registrations#resend-a-user-registration-verification-email with sendVerifyRegistrationEmail to false to get a verificationId and then this method to actually verify the number with that verificationId: https://fusionauth.io/docs/v1/tech/apis/registrations#verify-a-user-registration
        So basically you aren't sending any emails at all, you're just using the method calls to update the state of the user to verified.
        Does that help?
        • M
          mehr.prs
          Yeah, thanks.
          And just another question: do you have any plan to support phone number just like email (to register using phone field, verify using SMS,..)?
            A Former User
            Hi @mehr-prs. We have an open issue that is tracking this:
            https://github.com/FusionAuth/fusionauth-issues/issues/1
            This feature is to support multiple identities, but it also covers adding new identity types. As part of this feature, we likely will implement support for phone number identities including full validation and verification for them.
            Please upvote that issue if you feel it covers your requirements. This helps us prioritize features on our roadmap for the rest of 2020.
              Please feel free to vote for the issue @mehr-prs , if it is important to you. Here's the general FusionAuth roadmap guidance: https://fusionauth.io/community/forum/topic/172/the-fusionauth-roadmap
                dan @dan
                Note that this functionality (logging in with a phone number) was delivered in 1.59.
                More details here: https://fusionauth.io/blog/announcing-fusionauth-1-59
                S 1 Reply Last reply Reply Quote 0
                • S
                  sjames05569 @dan
                  I've found that setting the mobile number as the loginId is the most reliable way to handle this right now. You can just tweak the theme labels to say 'Mobile Number' instead of 'Username' so it's clear to the users. It’s a bit of a manual setup for the SMS verification part via the API, but it gets the job done without waiting for a native feature update.
