    Logging format for FusionAuth
    logging fargate
    4.7k
      I was wondering if anyone knew what logging library is used in FA? We are running on Fargate and want to detect errors in the cloudwatch logs using a lambda script and cloudwatch subscription filters, but it would be helpful to know if there is a format used when those message appear or if they are just free form text we will have to parse.
        We use logback.
        As of version 1.19.0, here is the logging pattern: <pattern>%d{"yyyy-MM-dd h:mm:ss.SSS a"} %-5level %logger{75} - %msg%n</pattern>
        Older versions, prior to 1.19.0, use this pattern <pattern>%d{"MMM dd, yyyy h:mm:ss.SSS a"} %-5level %logger{75} - %msg%n</pattern>.
