    Generated api key not an UUID but required in Python client
    2.0k
    • Y
      yet
      I am playing with FusionAuth and created some API keys:
      The Python client seems to require a valid UUID a api key since the following code does not work (taken from the Python client examples):
      client = FusionAuthClient('4zs15CcJJsczlYjeL62bltfbsqbxMZp4m43epG56gsA', 'http://127.0.0.1:9011')
      user_request = {
          'sendSetPasswordEmail': False,
          'skipVerification': True,
          'user': {
              'email': 'art@vandaleyindustries.com',
              'password': 'password'
      client_response = client.create_user(None, user_request)
      The API return this
      {'error_response': {'fieldErrors': {'user': [{'code': '[missing]user', 'message': 'Your request is missing the User information as JSON in the entity-body.'}], 'userId': [{'code': '[couldNotConvert]userId', 'message': "Invalid userId on the URL [{'sendSetPasswordEmail': False, 'skipVerification': True, 'user': {'email': 'art@vandaleyindustries.com', 'password': 'password'}}]. This must be a valid UUID String (e.g. 25a872da-bb44-4af8-a43d-e7bcb5351ebc)."}]}}, 'exception': None, 'response': <Response [400]>, 'success_response': None, 'status': 400}
      The error is obviously This must be a valid UUID String but why does not FusionAuth create a proper UUID? Even creating a new API key with my own provided UUID causes the same issue...anything I am missing here?
        Hiya,
        It looks like there's an error in our sample code.
        If you replace
        with
        client_response = client.create_user(user_request)
        then the user is created.
        I will file an issue on that library repo.
        Hope this helps.
          Ah, looks like someone else already shared a fix. https://github.com/FusionAuth/fusionauth-python-client/pull/6
