    Multi-Tenant Tenant specific IDP
    1.1k
    • U
      ubreddy
      I have a B2B SaaS application which is multitenant...
      Each customer tenant can have their own IDP ( Azure, Okta , Google etc )
      Could not find documentation on how to configure tenant specific IDP ... Is that not possible?
      I see that feature available in Keycloak where idp is available at tenant level (realm)..
        Hiya!
        With FusionAuth, identity providers are global objects. You configure them to apply to given applications (via enabling them) using the API or the UI. Applications are scoped to a tenant.
        So, if you wanted to make sure that a customer had Okta enabled, you'd do the following:
        • Set up an Okta OIDC identity provider
        • Create a tenant for the customer
        • Create an application in that tenant
        • Enable the Okta OIDC identity provider for that application
        More details here: https://fusionauth.io/docs/v1/tech/identity-providers/
        HTH.
