    Connecting to postgresql sitting behind HAProxy
    2.3k
    • H
      hvpavan
      hi,
      I have a the following cluster setup for my database:
      HAproxy-> PGBouncer -> Postgresql.
      db configuration in fusionauth.properties
      database.url=jdbc:postgresql://10.10.1.1:4242/fusionauth
      Error logs:
      *2021-01-22 9:20:50.476 PM INFO com.inversoft.jdbc.hikari.DataSourceProvider - Connecting to PostgreSQL database at [jdbc:postgresql://10.10.1.1:4242/fusionauth]
      2021-01-22 9:20:50.479 PM WARN com.zaxxer.hikari.HikariConfig - HikariPool-1 - idleTimeout has been set but has no effect because the pool is operating as a fixed size pool.
      2021-01-22 9:20:50.480 PM INFO com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Starting...
      2021-01-22 9:20:50.512 PM ERROR com.zaxxer.hikari.pool.HikariPool - HikariPool-1 - Exception during pool initialization.
      org.postgresql.util.PSQLException: The connection attempt failed.
      Caused by: java.io.EOFException: null
      at org.postgresql.core.PGStream.receiveChar(PGStream.java:372)
      at org.postgresql.core.v3.ConnectionFactoryImpl.enableSSL(ConnectionFactoryImpl.java:416)
      at org.postgresql.core.v3.ConnectionFactoryImpl.tryConnect(ConnectionFactoryImpl.java:140)
      at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:197)
      ... 298 common frames omitted*
      Has someone managed to connect fusionauth through HAproxy?
      Thank you!
        Does this happen regularly, or intermittently? It looks like some kind of SSL issue from the stacktrace, but I'm afraid I don't have any experience with this configuration.
        Another troubleshooting approach would be removing components to see if that changed the behavior.
        Or you could also search for interactions between Hikari (the java connection pooling system FusionAuth uses) and haproxy.
        Sorry I don't have a better answer for you. Please let us know what you end up finding out!
