    Using custom parameters with login page
    4.0k
    • M
      maciej.wisniowski Power User
      Hi
      I have a use case where I'd like to customize the FA login page based on the parameters sent in the request. I mean that my application will add an extra parameter during redirect to the FusionAuth /oauth2/authorize URL. I know that I can access request parameters in the login page template (OAuth authorize) but as soon as a user tries to log in and an error occurs (eg. invalid password) all the request parameters are gone (page reload).
      So far I've found that I can use the user_code parameter (as I'm not using device flow) to achieve what I need. user_code is available all the time in the template, even after page reload, but is there any other option to do it? Some extra user_parameters would be great.
      • M
        Answering to myself. Seems I can do the following:
        [#if request.getParameter('custom_parameter')??]
                  [#global custom_parameter = request.getParameter('custom_parameter')?string /]
                  [@helpers.hidden name="custom_parameter" /]
        [/#if]
        </form>
        which just passes the parameter in the input field making it available after the form submit
          @maciej-wisniowski said in Using custom parameters with login page:
          I did not know you could do that. Thanks for sharing your solution!
