    Is it possible to restrict admin permissions to specific tenants?
    • L
      lucas.loreggia
      Is it possible that a user with admin UI access can only see/manage users of a specific tenant, alternatively only of a specific application?
      Thanks for your help.
      • joshuaJ
        joshua
        Hi @lucas-loreggia,
        Unfortunately, this is not yet an option within FusionAuth but there is an open issue! See current discussion under issue 91. Please note, that the issue does document a workaround, using the API.
        I should also point out, while not specifically the use case you are asking for here, we do have the ability to form roles, as mentioned at the bottom of the issues post.
        I hope this helps!
        Josh
