    How do I query a bunch of Users and their associated data? Is it better to use the API or the UI?
    10.0k
    • joshuaJ
      joshua
      • joshuaJ
        joshua
        Both the API and the UI can pull User Data.
        Via API
        Docs are here:
        • https://fusionauth.io/docs/v1/tech/apis/users/#search-for-users
        • https://fusionauth.io/docs/v1/tech/apis/users/#elasticsearch-search-engine
        Via UI
        The functionality is nested under the user tab on the upper left nav.
        • From there click on the advanced button.
        • From there you can enter your query in the search bar.
        • Note: If you want to see how the query is constructed, there is also a toggle - Show Elasticsearch Query
        • https://fusionauth.io/docs/v1/tech/core-concepts/users/#user-search can guide you through a simple user query.
