I am trying to connect to a postgres db system with ssl, the tls1.3 config seems to have something in the certificate so that the handshake fails (all other clients I use with nodejs and python work with it)
jdbc:postgresql://hostname:26257/fusionauth?ssl=true
so far it seems like openjdk had a bug with this https://bugs.openjdk.java.net/browse/JDK-8236039
any ideas of how to solve it?
Caused by: javax.net.ssl.SSLHandshakeException: extension (5) should not be presented in certificate_request
at java.base/sun.security.ssl.Alert.createSSLException(Alert.java:131)
at java.base/sun.security.ssl.Alert.createSSLException(Alert.java:117)
at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:312)
at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:268)
at java.base/sun.security.ssl.TransportContext.fatal(TransportContext.java:259)
at java.base/sun.security.ssl.SSLExtensions.<init>(SSLExtensions.java:90)
at java.base/sun.security.ssl.CertificateRequest$T13CertificateRequestMessage.<init>(CertificateRequest.java:819)
at java.base/sun.security.ssl.CertificateRequest$T13CertificateRequestConsumer.consume(CertificateRequest.java:923)
at java.base/sun.security.ssl.SSLHandshake.consume(SSLHandshake.java:396)
at java.base/sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:445)
at java.base/sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:423)
at java.base/sun.security.ssl.TransportContext.dispatch(TransportContext.java:182)
at java.base/sun.security.ssl.SSLTransport.decode(SSLTransport.java:167)
at java.base/sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1462)
at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(SSLSocketImpl.java:1370)
at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:437)
at org.postgresql.ssl.MakeSSL.convert(MakeSSL.java:41) -
Solved by:
- name: FUSIONAUTH_APP_ADDITIONAL_JAVA_ARGS value: "-Djdk.tls.client.protocols=TLSv1.2" -
Thanks for sharing @michael-schramm! Glad you got it working!
-Josh
Looks like this is fixed in openjdk 15, so will be picked up when we roll that out (no timeline, but we are on 14 now).
