    X-Frame-Options and silent refresh
    2.9k
    • D
      dane.roe
      I'm attempting to migrate an angular application across from Auth0 to FusionAuth. I am using angular-oauth2-oidc library to replace the Auth0 library. The issue I am having is using implicit flow and the silent refresh option. The Fusionauth server seems to deny X-Frame-Options, so silent refresh will not work. Auth0 had an option to allow X-Frame-Options in the library, but I can't find whereabouts to allow this in FusionAuth. I have added X-Frame-Options in the allowed headers of the CORS setting, but this does not seem to make a difference. Any ideas appreciated. I realise Implicit Flow is not considered best practice, however I'm trying not to rewrite the entire auth service in the angular application.
        Hi,
        So I'm not intimately familiar with this use case, but I have a couple of pointers.
        Did you add X-Frame-Options to the exposed headers in the System setting? (This is more of a guess than a recommendation 🙂 .)
        Silent refreshes have some other issues. This github issue may be of interest: https://github.com/FusionAuth/fusionauth-issues/issues/521 . It points to a workaround: https://stackoverflow.com/questions/55859793/is-prompt-none-for-silent-refresh-in-a-spa-possible-with-fusionauth-and-its-prov where there's actually a suggestion to tweak the web.xml file.
        Finally, if you have a support contract with us, please open a ticket.
        • L
          linehammer
          This post is deleted!
