Navigation
    • Search
    2. andres.garcia
    A
    • Topics 4
    • Posts 6
    • Best 2
    Posts made by andres.garcia
    • Extend SSO session
      Hi everyone, is there a way to extend the SSO session programmatically? I'm wondering if even redirecting the user to the login page while still logged will extend the SSO session.
      Thank you.
      posted in Q&A
      A
      andres.garcia
    • RE: NameIDPolicy Transient
      @andres-garcia Nothing to do here? somebody?
      posted in General Discussion
      A
      andres.garcia
    • NameIDPolicy Transient
      Hi there I'm trying to integrate with docebo.com but I'm getting this error
      The error code is [InvalidNameIDPolicy] and the error message is [The AuthnRequest contained an invalid NameID policy. FusionAuth only supports the following NameID formats [urn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress, urn:oasis:names:tc:SAML:2.0:nameid-format:persistent, urn:oasis:names:tc:SAML:1.1:nameid-format:unspecified].]
      I noticed this in the auth request
      <samlp:NameIDPolicy Format="urn:oasis:names:tc:SAML:2.0:nameid-format:transient" AllowCreate="true"/>
      There is any way I can solve this problem or Docebo is not compatible with fusionauth =(
      I'm using version 1.30.2
      A
      andres.garcia
    • RE: Update connectorId on User?
      Hey @joshua, I was trying to provision an external service when my user logged in, and I was thinking to use a connector to get the request and then fallback to FusionAuth authentication. Still, I realized that when the user is already created on FusionAuth it never touch the other connector. So I was trying to do it that way because I can't provision the service async using the webhooks.
      posted in Q&A
      A
      andres.garcia
    • Update connectorId on User?
      There is any way to update or change the connectorId of an already created user?
      posted in Q&A
      A
      andres.garcia
    • SSO via /api/login
      Hi everyone I wonder if this scenario is doable using FusionAuth
      I have my FusionAuth installed and two Applications, App A and App B
      App A sign-in with FusionAuth through PHP using /api/login endpoint and that works great.
      App B sign-in with FusionAuth using SAML as a service provider and also works great.
      But I have a problem right now that is I would like that my already logged in users in App A can Sign-in in App B without entering username and password again, so that is basically SSO the question is there is any way to initiate an SSO session using the /api/login endpoint instead of using the standard hosted login page.
      Thank you and you have a really wonderful product.
      A
      andres.garcia
