Been struggling for 3 days to get past this ip address took too long to respond issue.
fusionauth-app.log:
2025-04-22 04:12:14.129 PM INFO io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Loading FusionAuth configuration file [/var/www/html/fusionauth/config/fusionauth.properties]
2025-04-22 04:12:14.130 PM INFO io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Dynamically set property [fusionauth-app.url] set to [http://localhost:9011]
2025-04-22 04:12:14.131 PM INFO com.inversoft.configuration.BasePropertiesFileInversoftConfiguration -
- Overriding default value of property [fusionauth-app.runtime-mode] with value [development]
- Overriding default value of property [search.type] with value [database]
2025-04-22 04:12:14.310 PM INFO com.inversoft.maintenance.MaintenanceModePoller - Poller started to Wait for configuration to be completed.
2025-04-22 04:12:14.312 PM INFO io.fusionauth.app.primeframework.FusionHTTPContextAuthSetup - Initializing the FusionAuth HTTP Context.
2025-04-22 04:12:14.362 PM INFO i.f.app.maintenance.guice.FusionAuthInteractiveMaintenanceModeModule -
--------------------------------------- Entering Maintenance Mode ---------------------------------------
2025-04-22 04:12:14.419 PM INFO io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Loading FusionAuth configuration file [/var/www/html/fusionauth/config/fusionauth.properties]
2025-04-22 04:12:14.419 PM INFO io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Dynamically set property [fusionauth-app.url] set to [http://localhost:9011]
2025-04-22 04:12:14.420 PM INFO com.inversoft.configuration.BasePropertiesFileInversoftConfiguration -
2025-04-22 04:12:14.421 PM INFO com.inversoft.maintenance.MaintenanceModePoller - Poller started to Wait for configuration to be completed.
2025-04-22 04:12:14.422 PM INFO io.fusionauth.app.primeframework.FusionHTTPContextAuthSetup - Initializing the FusionAuth HTTP Context.
2025-04-22 04:12:14.431 PM INFO org.primeframework.mvc.PrimeMVCRequestHandler - Initializing Prime
2025-04-22 04:12:14.432 PM INFO org.primeframework.mvc.PrimeMVCRequestHandler - Initializing Prime
2025-04-22 04:12:14.433 PM INFO io.fusionauth.http.server.HTTPServer - Starting the HTTP server. Buckle up!
2025-04-22 04:12:14.440 PM INFO io.fusionauth.http.server.HTTPServer - HTTP server listening on port [9011]
2025-04-22 04:12:14.441 PM INFO io.fusionauth.http.server.HTTPServer - HTTP server started successfully
2025-04-22 04:12:14.441 PM INFO io.fusionauth.http.server.HTTPServer - Starting the HTTP server. Buckle up!
2025-04-22 04:12:14.442 PM INFO io.fusionauth.http.server.HTTPServer - HTTP server listening on port [9012]
2025-04-22 04:12:14.442 PM INFO io.fusionauth.http.server.HTTPServer - HTTP server started successfully
any assistance will be greatly appreciated
