Hi,
I'm trying to get this working - specifically to fetch the Azure AD Groups list.
The LAMBDA does not have the required information in order to make the requested API calls into Azure though - we need the "access_token". It is shown in the debug for the external identity provider, but I need it to be passed into the Lambda so that I can use it to make further API calls into Azure (specifically https://learn.microsoft.com/en-us/graph/api/user-list-memberof?view=graph-rest-1.0&tabs=http)
Is there a way I can get an access token from within the Lambda?
OpenID Connect IdP Response Debug Log for [Cybanetix Azure AD] [00c92a11-475e-4207-ae33-XXXXXXXXXXXXX]
7/1/2023 07:33:38 AM Z Call the configured Token endpoint [https://login.microsoftonline.com/5f6cb372-3153-4b59-b2ab-XXXXXXXXXXXXX/oauth2/token]
7/1/2023 07:33:38 AM Z Endpoint returned status code [200]
7/1/2023 07:33:38 AM Z Access Token Response:
"token_type" : "Bearer",
"expires_in" : "3599",
"ext_expires_in" : "3599",
"expires_on" : "1688200418",
"access_token" : "YYYYYYYYYYYYYYYYYYYYYYYYYYY",
"refresh_token" : "HHHHHHHHHHHHHHHHHHHHHHHHH",
"id_token" : "KKKKKKKKKKKKKKKKKKKKKKKKKKKK"
7/1/2023 07:33:38 AM Z Call the configured Userinfo endpoint [https://login.microsoftonline.com/5f6cb372-3153-4b59-b2ab-XXXXXXXXXX/openid/userinfo]
7/1/2023 07:33:38 AM Z Build a new user object from the returned Userinfo response:
"amr" : "["pwd"]",
"family_name" : "Kite",
"given_name" : "Bradley",
"ipaddr" : "1.2.3.4",
"name" : "Bradley Kite",
"oid" : "f8e0dca2-7d1f-4a30-9f69-JJJJJJJJJJJJJ",
"onprem_sid" : "S-1-5-21-4038623597-1531512353-3070216767-1103",
"rh" : "NNNNNNNNNNNNNNNNNNNNNNNNNNNNNN",
"sub" : "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA",
"tid" : "5f6cb372-3153-4b59-b2ab-XXXXXXXXXXXXXXXX",
"unique_name" : "bradley.kite@cybanetix.com",
"upn" : "bradley.kite@cybanetix.com",
"uti" : "KKKKKKKKKKKKKKKKKKKKKKKKK",
"ver" : "1.0",
"wids" : "["62e90394-69f5-4237-9190-012177145e10","b79fbf4d-3ef9-4689-8143-76b194e85509"]",
"groups" : [ "["66d8de0b-511c-40f6-9bb4-336fa94490a2","7e3bec0e-7061-4b1d-8a7e-69ad326e393e","c1f5f027-3b4b-49a5-8dee-069ef62ae9f9","7cb99d2c-1474-480e-8717-760c540b6eb6","d6058a35-9ae3-4be6-9c84-95e58a2f9a29","d7d34237-a871-4aad-babf-e8e19ab03726","5ba09a3f-4568-41ac-a06b-2b28c7fd411e","4a326844-c011-4935-b44d-4ded98b7cfa3","0cb0665b-23c4-46d6-b397-56a94c99799b","67ecc67c-2b6c-41d2-89a6-e317794c410b","04282083-1a01-4f1e-a7d5-22bc6c2e6027","146973ae-64e3-41a5-9ab0-e8c89aa07a0a","d3d652c4-a54b-4213-982f-487d4f363a32","8545dff2-70e3-4b2f-ab29-dac881c39a9a","5deb9bf5-5abc-41ad-ab29-b7fa24e29176","aa665544-e3eb-4594-80f3-4f7964e6af05","3d18328f-1293-48cd-b218-b6a8d3a703e3","c564dd61-6d1b-43c7-8ec0-33f79707dcfa","15548cd8-65c1-4889-b978-a04d1f630e97","84d0320c-beb3-4012-a565-1696982d12b5","f74fc2bd-7995-4a14-be9e-6302716df420","0bc5a7a3-6d2b-444f-824b-5e73c5fbe471","a1d330da-388e-4b55-9f46-97376aab5422","95c361ce-b2b3-413f-bdb5-ab198cb5e689","3ee4b754-9660-45cf-96a0-eb341cf11ea2","3561d960-9354-4cee-bd34-06b72ffd1ee1","8b523c9e-1786-48e7-b7b6-14afe2b615d9","ff3c0a70-62c6-48f1-aaff-3df958e0bb6c"]" ]
7/1/2023 07:33:38 AM Z Linking strategy [LinkByEmail]
7/1/2023 07:33:38 AM Z Resolved email to [null]
7/1/2023 07:33:38 AM Z Resolved username to [null]
7/1/2023 07:33:38 AM Z Resolved unique Id to [jwSpJK9odbqmZkzqO5HzCLvUgKKksvUz1b5qsX7JxXA]
7/1/2023 07:33:38 AM Z Identity provider returned a unique Id [jwSpJK9odbqmZkzqO5HzCLvUgKKksvUz1b5qsX7JxXA].
7/1/2023 07:33:38 AM Z User with Id [cfb8a0fc-b0b0-448b-869b-efd8a0955887] is linked to this external user.
7/1/2023 07:33:38 AM Z Invoke configured lambda with Id [89e4f359-83b8-4ca5-9e7f-272d4bae9262]
7/1/2023 07:33:38 AM Z Updating user:
"active" : true,
"breachedPasswordLastCheckedInstant" : 1647404340012,
"breachedPasswordStatus" : "None",
"connectorId" : "e3306678-a53a-4964-9040-AAAAAAAAAAAA",
"data" : { },
"email" : "bradley.kite@cybanetix.com",
"firstName" : "Bradley",
"fullName" : "Bradley Kite",
"id" : "cfb8a0fc-b0b0-448b-869b-GGGGGGGGGG",
"insertInstant" : 1598377522115,
"lastLoginInstant" : 1688196656636,
"lastName" : "Kite",
"lastUpdateInstant" : 1688196656636,
"memberships" : [ {
"data" : { },
"groupId" : "12e1f396-885f-45d0-9eb1-b69b5820ea19",
"id" : "e9b4f8cd-61f1-41e8-a270-06ddcf293d47",
"insertInstant" : 1647365944503
"passwordChangeRequired" : false,
"passwordLastUpdateInstant" : 1647365944496,
"preferredLanguages" : [ ],
"registrations" : [ ],
"tenantId" : "863a8e18-7ae4-8ad7-4fa0-XXXXXXXXXXXX",
"twoFactor" : {
"methods" : [ ],
"recoveryCodes" : [ ]
"uniqueUsername" : "bradley.kite",
"username" : "bradley.kite",
"usernameStatus" : "ACTIVE",
"verified" : true
7/1/2023 07:33:38 AM Z User is already registered for application with Id [6784dd47-e284-4425-8394-8c3b1d031468].
7/1/2023 07:33:39 AM Z User has successfully been reconciled and logged into FusionAuth.
7/1/2023 07:33:39 AM Z Authentication type: OPENID_CONNECT
7/1/2023 07:33:39 AM Z Authentication state: Authenticated
