    2. colin.orr
    C
    • Topics 1
    • Posts 1
    • Best 0
    Posts made by colin.orr
    • Setting well-known IDs for identity providers in the kickstart file
      I'm using the Kickstart approach to setup FusionAuth for local development and I'd like to create identity providers with well-known IDs so I can reference them in my application.
      I was hoping to specify a UUID at the end of the URL like you can for other API resources:
      POST /api/identity-provider/11111111-1111-1111-1111-111111111111
      but it seems this UUID is ignored and a random one is generated instead.
      For context, I need to reference these IDs in my application so I can use them with the idp_hint parameter to let users log in directly to an identity provider.
      Is there another way to do this via Kickstart?
      posted in Q&A
      C
      colin.orr
