    2. daniel.b
    D
    • Topics 1
    • Posts 1
    • Best 0
    Posts made by daniel.b
    • Mysql Issue
      Hello,
      I have installed the system today and everything works like adding users, applications etc however i can view applications on the application page as there is an error of FusionAuth encountered an unexpected error. Please review the troubleshooting guide found in the documentation for assistance and the available support channels.
      Looking at the logs it reads:
      Caused by: java.sql.SQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '>> '$.state' = 'Active'' at line 3
      at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:121)
      at com.mysql.cj.jdbc.exceptions.SQLExceptionsMapping.translateException(SQLExceptionsMapping.java:122)
      at com.mysql.cj.jdbc.ClientPreparedStatement.executeInternal(ClientPreparedStatement.java:912)
      at com.mysql.cj.jdbc.ClientPreparedStatement.execute(ClientPreparedStatement.java:354)
      at com.zaxxer.hikari.pool.ProxyPreparedStatement.execute(ProxyPreparedStatement.java:44)
      at com.zaxxer.hikari.pool.HikariProxyPreparedStatement.execute(HikariProxyPreparedStatement.java)
      at org.apache.ibatis.executor.statement.PreparedStatementHandler.query(PreparedStatementHandler.java:65)
      at org.apache.ibatis.executor.statement.RoutingStatementHandler.query(RoutingStatementHandler.java:80)
      at org.apache.ibatis.executor.SimpleExecutor.doQuery(SimpleExecutor.java:65)
      at org.apache.ibatis.executor.BaseExecutor.queryFromDatabase(BaseExecutor.java:333)
      at org.apache.ibatis.executor.BaseExecutor.query(BaseExecutor.java:158)
      at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:110)
      at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:90)
      at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:154)
      ... 53 common frames omitted
      Any feedback on the issue is appreciated
      posted in Q&A
      D
      daniel.b
