I have been trying to integrate kube-oidc-proxy for fine grained k8s access and all though the configuration has been pretty standard. But when I login via the proxy
uing fusion auth as the authentication layer I am not able see the attached role.
Role is definetly attached to the user.
I also have double checked that has the correct application and there is nothing in fusion auth 's or kube oidc logs that stands out.
D
Posts made by divneetsingh.m
Fusionauth integrattion with kubeoidc proxy
