I do have a workaround. If I update the user twice when there is no current email (first time with a random address and the second time with the intended address) then the user reaches the desired state and the verification email is sent.
Posts made by eddie.whiteside
RE: No email verification if user created without an emailposted in Q&A
Hi,
Don't know if I'm doing something wrong or if there is a reason for this but I've come across a possible issue.
I have my tenant setup to verify email and verify email on change. If I create a user with no email through the API i.e.
POST api/user { "sendSetPasswordEmail": false, "user": { "password": "pass", "username": "uniqueName" } }Then update the users email email:
PATCH api/user/{id} { "user": { "email": "me@example.com" } }The response comes back showing the user as verified (and no email is received):
{ "user": { "active": true, ... "verified": true } }If I repeat the process but insert an email on the initial post then the subsequent PATCH triggers the email and sets
verifiedto false.This is a flow that we would find extremely useful in our sign-up process as we do not expect users to set-up their email before we create their identity in fusion.
Let me know if there is a workaround for this or whether I should raise a bug report.
Many thanks,
Eddie
