    2. eric.vigiani
    E
    • Topics 2
    • Posts 2
    • Best 1
    Posts made by eric.vigiani
    • Lost acess to fusionatuh admin dashboard
      I accidentally lost my admin privileges on FusionAuth and I am unable to access the admin dashboard, now I cannot access the admin panel to manage my application settings. I would like to restore my admin privileges to regain control of the system.
      I went into the default Fusionauth application and unchecked the admin option in the roles.
      I have a cloud hosting and I am the only user there.
      posted in Q&A
      E
      eric.vigiani
    • Problem running Flask server - Dashboard page not found (404 error)
      I'm facing an issue while setting up FusionAuth with Flask. I followed the configuration steps to integrate FusionAuth into my Flask application, but I'm having difficulty accessing the dashboard page after starting the Flask server.
      Here is the configuration I'm using:
      I have a Flask application with the following routes:
      Main route (/) that redirects to the FusionAuth login page.
      Logout route (/logout) that clears the user session and redirects to the main page.
      Dashboard route (/dashboard) that should display the dashboard page with additional user information.
      I created the corresponding HTML pages (home.html, dashboard.html) and placed them in the 'templates' folder of my Flask project.
      I ensured that the routes are correctly defined in the code and that the URLs are properly specified in the HTML pages.
      I verified that all the necessary dependencies are correctly installed.
      After starting the Flask server, I can access the home page and successfully login using FusionAuth. However, when I try to access the dashboard page (/dashboard), I receive a 404 error indicating that the page was not found.
      in the flask documentation https://fusionauth.io/docs/v1/tech/tutorials/integrate-python-flask, i am trying to undestand this section.
      posted in General Discussion
      E
      eric.vigiani
